Skip to main content
PAB
Programmable Active Buffers pab_front_panel
PAB is a utility for distributing and delaying signals. Duplicate a clean copy of a signal, or delay it in increments of 16 nanoseconds.
With delay times in the range of tens of nanoseconds, the result is an image shifted slightly to the right. Different modules delay signals by different amounts. In complex patches, this can be a problem. When signals are combined, they may be out of horizontal registration. PAB addresses this by inserting strategic delays to make everything line up.
Key Specifications
Mounting Width4 HP
Power Consumption12V @ 50mA
Power Connectors10 pin EuroRack ribbon, 2.1mm DC barrel
Video SyncNone
IncludedDC barrel power cable, EuroRack power cable, red panel, green panel, blue panel
Front Panel Options
PAB ships with a black front panel installed. Red, green and blue panels are also included.
pab_all_front_panels
Connectors
pab_controls_connectors_indicators
Understanding Cascading Input Jacks
PAB uses switched, or normalled, connections between its input jacks. With no cable inserted, a signal flows down from one input jack to another. This connection is overridden when a cable is inserted. Normalled inputs are indicated on the front panel with arrows.
pab_understanding_cascading_input_jacks
Installation
pab_mounting_power_sync
Requirements
  • EuroRack enclosure
  • 2.1 mm DC barrel power cable or EuroRack power cable (both options included)
  • Eurorack power for PAB requires a 16-pin to 10-pin ribbon cable
  • Two M2.5 x 6mm mounting screws, or screws provided or specified by the enclosure manufacturer
Procedure
Full Specifications
Pronunciationpab
Mounting Width4 HP
Mounting Hole Count2
Power Consumption12V @ 50 mA
Power Connectors10-pin EuroRack ribbon, 2.1mm DC barrel
Input Impedance1M ohms
Output Impedance75 ohms
Input Protection Range+/-20V
Input Clipping Range+/-2.5V
Output Range+/-2.5V
Propagation Delay16ns
Module Width20.32 mm
Module Height128.5 mm
Product Box Width4 in / 101.6 mm
Product Box Height2 in / 50.8 mm
Product Box Depth6 in / 152.4 mm
EuroRack Power Cable Type10-pin to 16-pin
Video SyncNone
Maintenance
Keep the module free of dust and debris by performing periodic cleaning. Spots may be cleaned from the frontpanel with a microfiber cloth and isopropyl alcohol or other electronics cleaner.
Hardware Revisions
PAB-RevA
Initial prototype, January 2025
PAB-RevB
Initial production version, February 2025
PAB-REVB Schematic Diagram
Download PDF
PAB-REVB Interactive Bill of Materials
Download ZIP
DIY
PAB is available as an assembled module, a full DIY kit, or a partial DIY kit.
Downloads for the complete schematic and an interactive HTML Bill of Materials are found in the Hardware Revisions section above.
Partial DIY Components
The partial DIY kit from LZX includes the printed circuit board and front panel. The following components must be purchased separately from electronics parts vendors.
ManufacturerManufacturer Part NumberDescriptionQuantityReference Designators
Wenzhou QingPu Electronics Co., LtdWQP-WQP518MA3.5mm Jack Mono Switched13J1, J2, J3, J4, J5, J6, J8, J9, J14, J15, J16, J17, J18
Pin Header Pitch 0.1in 2X5 Male Shrouded1J12
Wurth Elektronik694106402002DC Jack Vertical 2.1mm Barrel1J13
Recom TechnologiesR-78K3.3-0.5DC/DC Converter Submodule 3.3V1U6
Assembly Instructions
This assembly job is recommended for intermediate level DIYers who are comfortable soldering thru hole joints in close proximity to surface mounted parts.
  1. Mount and solder rear facing through hole parts first, in this order: pin header, DC/DC converter, DC barrel jack.
  2. Mount and solder front facing jacks next.
  3. Attach the front panel and secure it with mounting nuts for the jacks.
