Skip to main content
LNK
Passive Links lnk_front_panel
Key Specifications
ParameterValue
Mounting Width4 HP
Power ConsumptionNone
Power ConnectorsNone
Video SyncNone
Connectors
lnk_controls_connectors_indicators
Operation
Understanding Cascading Input Jacks
LNK uses switched, or normalled, connections between its input jacks. With no cable inserted, a signal flows down from one input jack to another. This connection is overridden when a cable is inserted. Normalled inputs are indicated on the front panel with arrows.
lnk_understanding_cascading_input_jacks
Example Patches
lnk_mults
Installation
lnk_mounting_power_sync
Requirements
  • EuroRack enclosure.
  • Two M2.5 x 6mm mounting screws, or screws provided or specified by the enclosure manufacturer.
  • #1 Phillips head screwdriver, or hand tool provided or specified by the enclosure manufacturer.
Procedure
  • Carefully test fit the module in the open space in the EuroRack enclosure. If it is obstructed by the enclosure or any internal assemblies, abort this procedure.
Full Specifications
Technical Data
Mounting Width4 HP
Mounting Hole Count2
Module Width20.32 mm
Module Height128.5 mm
Product Box Width4 in / 101.6 mm
Product Box Height2 in / 50.8 mm
Product Box Depth6 in / 152.4 mm
Video SyncNone
Maintenance
Hardware Revisions
LNK-RevA
Initial production version, February 2025
LNK-RevA Schematic Diagram
Download PDF
LNK-RevA Interactive Bill of Materials
Download ZIP
DIY
LNK is available as an assembled module, a full DIY kit, or a partial DIY kit.
Downloads for the complete schematic and an interactive HTML Bill of Materials are found in the Hardware Revisions section above.
Partial DIY Components
The partial DIY kit from LZX includes the printed circuit board and front panel. The following components must be purchased separately from electronics parts vendors.
ManufacturerManufacturer Part NumberDescriptionQuantityReference Designators
Wenzhou QingPu Electronics Co., LtdWQP-WQP518MA3.5mm Jack Mono Switched16J1, J2, J3, J4, J5, J6, J7, J8, J9, J10, J11, J12, J13, J14, J15, J16
Assembly Instructions
This assembly job is recommended for intermediate level DIYers who are comfortable soldering thru hole joints in close proximity to surface mounted parts.
  1. Mount and solder front-facing jacks.
  2. Attach the front panel and secure it with mounting nuts for the jacks.
