Skip to main content
Serial Port Guide
Videomancer exposes a text-based command interface over its USB-C connection. Any serial terminal or scripting language with serial port support can send commands and receive responses. This opens the door to automation, preset management, integration with custom software, and deep system introspection — all from a simple terminal window.
Connection Setup
  1. Connect Videomancer to your computer via the USB-C port.
  2. Videomancer enumerates as a USB CDC ACM virtual COM port.
  3. Open the port at any baud rate — the baud rate setting is ignored for USB CDC. Common tools include:
    • macOS / Linux: screen /dev/ttyACM0, picocom, minicom, or Python's pyserial
    • Windows: PuTTY, Tera Term, or any COM port terminal
No login or authentication is needed — Videomancer accepts commands immediately.
Wire Protocol
Sending Commands
Send a newline-terminated (\n) ASCII string:
<command> [arguments]\n
  • Lines are limited to 511 bytes before the newline.
  • A carriage return (\r) is treated as a newline.
  • Non-printable characters below 0x20 (except Backspace and Delete) are silently dropped.
  • Backspace (0x08) and Delete (0x7F) erase the most recent character.
Receiving Responses
PrefixMeaningFormat
@Success@<command>:<payload>\n
!Error!<code>:<message>\n
(none)Log outputPlain text line (when logging is active)
The payload is either a simple string (e.g., ok) or a JSON object. All responses are newline-terminated.
Error Codes
CodeNameDescription
1unknown_commandUnrecognized command
2parse_errorMalformed arguments
3service_unavailableRequired service not ready
4buffer_overflowCommand exceeded 511-byte limit
5not_connectedCDC port not connected
6file_not_foundFile or directory not found
7io_errorFilesystem I/O failure
8sd_not_mountedSD card not mounted
9path_too_longPath exceeds maximum length
10invalid_pathPath is malformed (e.g., contains ..)
Commands
General
version
Returns the firmware version string.
> version
@version:2.1.0
Development builds include commit count and hash:
@version:2.1.0-rc.1+15.abc1234
serial
Returns the board's unique hardware ID as a hex string.
> serial
@serial:E6614104035B8F2F
status
Returns system status as JSON.
> status
@status:{"current_program":"cascade","video_standard":"hd_1080i","sd_mounted":true}
help
Lists all available commands, pipe-delimited.
> help
@help:version|serial|status|reboot bootloader|programs list|program load|...
reboot bootloader
Reboots Videomancer into USB mass-storage (BOOTSEL) mode for firmware update. The CDC connection drops immediately — reconnect after flashing new firmware.
> reboot bootloader
FPGA Programs
programs list [offset]
Lists installed FPGA programs with paginated JSON output. Programs are listed in directory order.
> programs list
@programs:{"count":343,"programs":["afterdark","afterimage","alcove",...],"more":true,"next":40}
FieldTypeDescription
countnumberTotal number of installed programs
programsarrayProgram names in this page
morebooleantrue if more pages remain
nextnumberOffset for the next page (present only when more is true)
To retrieve all programs, page through until more is false:
> programs list
> programs list 40
> programs list 80
program load <name>
Loads an FPGA program by name. Matching is case-insensitive.
> program load cascade
@program:ok
This triggers the full program-load workflow: video sync suspension, loading screen, FPGA bitstream load, factory preset application, and video output resume.
tip
After sending program load, allow approximately 1–2 seconds for the full load workflow to complete before querying program state or presets.
program state
Returns the current modulator state for all 12 parameter channels as JSON.
> program state
@program:{"ch":[512,512,512,512,512,512,0,0,0,0,0,512],"mod":[...]}
Program Presets
Presets come in two types:
  • Factory presets — bundled with the FPGA program, read-only.
  • User presets — saved by the user, stored in flash.
program presets list
Lists all presets for the currently loaded program.
@program:{"factory":[{"n":"Default","m":[512,512,...]}],"user":[...],"flash_free":131072}
program presets get <index> <type>
Returns full preset data. Type is factory or user.
> program presets get 0 factory
@program:{"n":"Default","m":[512,512,512,512,512,512,0,0,0,0,0,512]}
User presets include additional modulation fields: t (time), sp (space), sl (slope), and sr (source).
program presets apply <index> <type>
Applies a preset by numeric index and type.
> program presets apply 0 factory
@program:ok
program presets apply <name>
Applies a preset by name (case-insensitive). Factory presets are searched first, then user presets.
> program presets apply Default
@program:ok
program presets save <index> <name> [data]
Saves the current modulator state as a user preset at the given slot.
> program presets save 0 MyPreset
@program:ok
To save explicit values, append parameter data:
> program presets save 0 MyPreset m:512,512,512,512,512,512,0,0,0,0,0,512
Full modulation data fields: m: (manual), t: (time), sp: (space), sl: (slope), sr: (source).
program presets delete <index>
Deletes a user preset at the given index. Returns the updated preset list.
> program presets delete 2
@program:{"factory":[...],"user":[...],"flash_free":135168}
program presets rename <index> <name>
Renames a user preset.
> program presets rename 0 NewName
@program:ok
Settings
settings export
Exports all settings as a JSON object.
> settings export
@settings:{"video_routing_mode":0,"analog_video_in_mode":1,...}
settings import <json>
Imports settings from a JSON object. Replaces all settings atomically.
> settings import {"video_routing_mode":0,"analog_video_in_mode":1}
@settings:ok
MIDI Monitor
midi monitor on
Enables MIDI input monitoring. Incoming MIDI messages are printed as log lines.
> midi monitor on
@midi:ok
midi monitor off
Disables MIDI monitoring.
> midi monitor off
@midi:ok
midi monitor verbose
Enables verbose MIDI monitoring with hex dumps.
@midi:ok
Filesystem
All filesystem commands operate on the SD card. Paths must begin with sd:/.
fs info
Returns filesystem mount status and capacity.
> fs info
@fs:{"sd_mounted":true,"sd_total":31914983424,"sd_free":31012864000}
fs ls [path]
Lists directory contents. Defaults to sd:/ if no path is given. Output is paginated JSON.
> fs ls sd:/programs
@fs:{"path":"sd:/programs","entries":[{"n":"cascade.vmprog","s":45056,"d":false},...]}
fs stat <path>
Returns file or directory metadata.
> fs stat sd:/programs/cascade.vmprog
@fs:{"path":"sd:/programs/cascade.vmprog","size":45056,"is_dir":false}
fs mkdir <path>
Creates a directory, including parent directories.
> fs mkdir sd:/presets
@fs:ok
fs rm <path>
Removes a file or empty directory.
> fs rm sd:/presets/old.json
@fs:ok
fs rename <old_path> <new_path>
Renames or moves a file or directory.
> fs rename sd:/presets/a.json sd:/presets/b.json
@fs:ok
fs read <path> <offset> <length>
Reads a chunk of a file. The response payload is base64-encoded.
> fs read sd:/programs/cascade.vmprog 0 256
@fs:SGVsbG8gV29ybGQ=...
fs write <path> <offset> <base64_data>
Writes a base64-encoded chunk to a file.
> fs write sd:/test.txt 0 SGVsbG8=
@fs:ok
Python Example
The following script demonstrates communicating with Videomancer using pyserial. It covers connection, paginated program listing, program loading, preset application, and settings export.
import serial
import json
import time
def open_videomancer(port="/dev/ttyACM0", timeout=2):
"""Open a serial connection to Videomancer."""
return serial.Serial(port, timeout=timeout)
def send_command(ser, command):
"""Send a command and return the response line."""
ser.reset_input_buffer()
ser.write(f"{command}\n".encode("ascii"))
line = ser.readline().decode("ascii").strip()
return line
def parse_response(line):
"""Parse a response line into (prefix, key, payload)."""
if line.startswith("@"):
key, _, payload = line[1:].partition(":")
return "ok", key, payload
elif line.startswith("!"):
code, _, message = line[1:].partition(":")
return "error", code, message
return "log", "", line
def get_json_response(ser, command):
"""Send a command and parse the JSON payload."""
line = send_command(ser, command)
status, key, payload = parse_response(line)
if status == "error":
raise RuntimeError(f"Error {key}: {payload}")
return json.loads(payload)
# --- Usage ---
ser = open_videomancer()
# Get firmware version
print("Version:", send_command(ser, "version"))
# List all programs (paginated)
all_programs = []
offset = 0
while True:
data = get_json_response(
ser, f"programs list {offset}" if offset else "programs list"
all_programs.extend(data["programs"])
if not data.get("more", False):
break
offset = data["next"]
print(f"Found {len(all_programs)} programs")
# Load a program
print(send_command(ser, "program load cascade"))
# Wait for load to complete
time.sleep(2)
# Apply a factory preset by name
print(send_command(ser, "program presets apply Default"))
# Export settings
settings = get_json_response(ser, "settings export")
print("Settings:", json.dumps(settings, indent=2))
ser.close()
Notes
  • Response buffer: Videomancer has a 768-byte response buffer. Commands that produce large output (e.g., programs list, fs ls) use pagination to stay within this limit.
  • Concurrent access: Only one serial terminal should be connected at a time. The shell service is single-threaded and does not support concurrent sessions.
  • SD card paths: All filesystem commands require paths prefixed with sd:/. The internal flash filesystem is not accessible via the serial shell.
