Videomancer Fault Codes Reference
When Videomancer encounters a fault, the LCD displays a hex code (e.g., 0x2C000008). Use this table to look up the meaning.
| Hex Code | Subsystem | Description |
| Core — Messaging Infrastructure | ||
0x00000001 | Core | Null receiver ID passed |
0x00000002 | Core | Null ticket ID passed |
0x00000003 | Core | Null requester in ticket |
0x00000004 | Core | Duplicate receiver registry entry |
0x00000005 | Core | Receiver not found in registry |
0x00000006 | Core | Message receiver registry full |
0x00000007 | Core | Message queue empty |
0x00000008 | Core | Message queue full |
0x00000009 | Core | Invalid message packet |
0x0000000A | Core | Re-entrant state transition |
0x0000000B | Core | State transition guard failed |
0x0000000C | Core | State machine rate-limited |
0x0000000D | Core | Machine already suspended |
0x0000000E | Core | Machine not started |
0x0000000F | Core | Machine already started |
0x00000010 | Core | Sequence already completed |
0x00000011 | Core | Stack machine at max depth |
0x00000012 | Core | Stack machine has no frames |
0x00000013 | Core | Retry machine retries exhausted |
0x00000014 | Core | Queue machine full |
0x00000015 | Core | Queue machine empty on advance |
0x00000016 | Core | Machine already registered |
0x00000017 | Core | Machine not found in registry |
0x00000018 | Core | Machine registry full |
0x00000019 | Core | Machine not suspended |
0x0000001A | Core | Pipeline has no data |
0x0000001B | Core | Pipeline stage stalled |
0x0000001C | Core | Request already pending |
0x0000001D | Core | No request pending |
0x0000001E | Core | Request timed out |
0x0000001F | Core | Watchdog deadline expired |
| Silicon — System Clock | ||
0x04000001 | System Clock | Self-test failed |
| Silicon — Critical Section | ||
0x04100001 | Critical Section | Self-test failed |
| Silicon — Watchdog | ||
0x04200001 | Watchdog | Timeout exceeds hardware maximum |
0x04200002 | Watchdog | Self-test failed |
| Silicon — GPIO | ||
0x04300001 | GPIO | Invalid pin number |
0x04300002 | GPIO | Self-test failed |
0x04300003 | GPIO | Operation not applicable |
0x04300004 | GPIO | Bus communication error |
| Silicon — SPI | ||
0x04400001 | SPI | Invalid SPI mode |
0x04400002 | SPI | Null buffer pointer |
0x04400003 | SPI | Self-test failed |
| Silicon — I2C | ||
0x04500001 | I2C | Device NACK (no acknowledge) |
0x04500002 | I2C | Bus error |
0x04500003 | I2C | Null data pointer |
0x04500004 | I2C | Self-test failed |
| Silicon — Flash | ||
0x04600001 | Flash | Address alignment error |
0x04600002 | Flash | Address range error |
0x04600003 | Flash | Null data pointer |
0x04600004 | Flash | Erase failed |
0x04600005 | Flash | Program (write) failed |
0x04600006 | Flash | Self-test failed |
| Silicon — Resets | ||
0x04700001 | Resets | Self-test failed |
| Silicon — Multicore | ||
0x04800001 | Multicore | Null entry function pointer |
0x04800002 | Multicore | Inter-core FIFO timeout |
0x04800003 | Multicore | Self-test failed |
| Silicon — UART | ||
0x04900001 | UART | Null buffer pointer |
0x04900002 | UART | Self-test failed |
| Silicon — Unique ID | ||
0x04A00001 | Unique ID | Self-test failed |
| Silicon — USB CDC | ||
0x04C00001 | USB CDC | Self-test failed |
0x04C00002 | USB CDC | Device not initialized |
| Silicon — PWM | ||
0x04D00001 | PWM | Invalid slice number |
0x04D00002 | PWM | Invalid channel (must be A or B) |
0x04D00003 | PWM | Self-test failed |
| Silicon — ADC | ||
0x04E00001 | ADC | Invalid input channel |
0x04E00002 | ADC | Not initialized |
0x04E00003 | ADC | Invalid round-robin channel mask |
0x04E00004 | ADC | FIFO not enabled |
0x04E00005 | ADC | Self-test failed |
0x04E00006 | ADC | Operation not applicable |
| Silicon — IRQ | ||
0x04F00001 | IRQ | Invalid IRQ number |
0x04F00002 | IRQ | Handler conflict (already set) |
0x04F00003 | IRQ | No user IRQ slots free |
0x04F00004 | IRQ | IRQ already claimed |
0x04F00005 | IRQ | Self-test failed |
| Silicon — DMA | ||
0x05000001 | DMA | No DMA channel free |
0x05000002 | DMA | Invalid channel number |
0x05000003 | DMA | Channel busy |
0x05000004 | DMA | No DMA pacing timer free |
0x05000005 | DMA | Invalid timer number |
0x05000006 | DMA | Self-test failed |
| Silicon — Random | ||
0x05200001 | Random | Entropy source exhausted |
0x05200002 | Random | Not initialized |
0x05200003 | Random | Self-test failed |
| Silicon — RTC | ||
0x05300001 | RTC | Not running |
0x05300002 | RTC | Invalid date/time value |
| Silicon — PLL | ||
0x05400001 | PLL | Invalid VCO frequency |
0x05400002 | PLL | Invalid post-divider |
0x05400003 | PLL | No valid PLL configuration found |
| Silicon — Clock Tree | ||
0x05500001 | Clock Tree | Invalid frequency |
0x05500002 | Clock Tree | Configuration failed |
| Silicon — Voltage Regulator | ||
0x05600001 | Voltage Regulator | Invalid voltage level |
0x05600002 | Voltage Regulator | Self-test failed |
| Silicon — Crystal Oscillator | ||
0x05700001 | Crystal Oscillator | Init failed |
0x05700002 | Crystal Oscillator | Self-test failed |
| Silicon — Hardware Timer | ||
0x05800001 | Hardware Timer | Invalid alarm number |
0x05800002 | Hardware Timer | No alarms available |
0x05800003 | Hardware Timer | Alarm target time missed |
0x05800004 | Hardware Timer | Invalid parameter |
| Silicon — Cache | ||
0x05900001 | Cache | Invalid address range |
0x05900002 | Cache | Self-test failed |
| Board — Video Decoder (ADV7181C) | ||
0x08100004 | Video Decoder | Unsupported video timing |
0x08100005 | Video Decoder | Unsupported video connector |
0x08100006 | Video Decoder | Invalid chip revision |
0x0810000A | Video Decoder | I2C communication error |
0x08100032 | Video Decoder | Self-test failed |
| Board — Video Encoder (ADV7393) | ||
0x08200001 | Video Encoder | Unsupported video timing |
0x08200002 | Video Encoder | Unsupported video connector |
0x0820000A | Video Encoder | I2C communication error |
0x08200033 | Video Encoder | Self-test failed |
| Board — HDMI Receiver (ADV7611) | ||
0x08300007 | HDMI Receiver | Unsupported video timing |
0x0830000A | HDMI Receiver | I2C communication error |
0x08300034 | HDMI Receiver | Self-test failed |
| Board — HDMI Transmitter (ADV7513) | ||
0x08400008 | HDMI Transmitter | Unsupported video timing |
0x0840000A | HDMI Transmitter | I2C communication error |
0x08400035 | HDMI Transmitter | Self-test failed |
| Board — LCD (ST7032) | ||
0x08700036 | LCD | Self-test failed |
| Board — ADC Capture | ||
0x08A00001 | ADC Capture | Not initialized |
0x08A00002 | ADC Capture | DMA channel claim failed |
0x08A00003 | ADC Capture | Already initialized |
| Kernel — Lifecycle | ||
0x0C300001 | Kernel Lifecycle | Invalid phase transition |
0x0C300002 | Kernel Lifecycle | Supervisor not registered |
0x0C300003 | Kernel Lifecycle | Message queue above capacity |
| Kernel — Capability Registry | ||
0x0C400001 | Capability Registry | Null capability pointer |
0x0C400002 | Capability Registry | Registry full |
0x0C400003 | Capability Registry | Duplicate capability |
| Timing Service | ||
0x10000001 | Timing | Timer not found |
0x10000002 | Timing | Timer already registered |
0x10000003 | Timing | Timer schedule full |
0x10000004 | Timing | Invalid duration |
0x10000005 | Timing | Invalid timer mode |
0x10000006 | Timing | Timer not paused (on resume) |
0x10000007 | Timing | Timer already paused |
0x10000008 | Timing | Message post failed |
| Logging Service | ||
0x14000001 | Logging | Sink array full |
0x14000002 | Logging | Invalid log level |
0x14000003 | Logging | Sink not found |
| Filesystem | ||
0x1C000001 | Filesystem | Generic error |
0x1C000002 | Filesystem | Drive not mounted |
0x1C000003 | Filesystem | File or folder not found |
0x1C000004 | Filesystem | No space left on drive |
0x1C000005 | Filesystem | File or folder already exists |
0x1C000006 | Filesystem | Invalid argument |
0x1C000007 | Filesystem | I/O error |
0x1C000008 | Filesystem | Too many open files |
0x1C000009 | Filesystem | Resource busy |
0x1C00000A | Filesystem | Write-protected media |
0x1C00000B | Filesystem | Invalid internal object |
0x1C00000C | Filesystem | Invalid drive ID |
0x1C00000D | Filesystem | No valid filesystem on media |
0x1C00000E | Filesystem | I/O timeout |
0x1C00000F | Filesystem | Invalid path or filename |
0x1C000010 | Filesystem | Path is a file, not a folder |
0x1C000011 | Filesystem | Path is a folder, not a file |
0x1C000012 | Filesystem | Folder not empty |
0x1C000013 | Filesystem | Bad file structure |
0x1C000014 | Filesystem | File too large |
0x1C000015 | Filesystem | Name too long |
0x1C000016 | Filesystem | Filesystem metadata corrupt |
0x1C000017 | Filesystem | SD card not detected |
0x1C000018 | Filesystem | Mount failed |
0x1C000019 | Filesystem | Unmount failed |
0x1C00001A | Filesystem | Invalid file ID |
0x1C00001B | Filesystem | File not open |
0x1C00001C | Filesystem | Invalid folder ID |
0x1C00001D | Filesystem | Driver registration table full |
0x1C00001E | Filesystem | Invalid driver |
0x1C00001F | Filesystem | Invalid mount prefix |
0x1C000020 | Filesystem | Media removed during operation |
| Settings | ||
0x20000001 | Settings | Preset not found |
0x20000002 | Settings | Storage full |
0x20000003 | Settings | Corrupt data |
0x20000004 | Settings | Setting not found |
0x20000005 | Settings | Settings working set full |
0x20000006 | Settings | I/O error during save/load |
0x20000007 | Settings | Setting already exists |
0x20000008 | Settings | Invalid preset name |
0x20000009 | Settings | Filesystem unavailable |
0x2000000A | Settings | Serialization buffer overflow |
0x2000000B | Settings | Value out of range |
0x2000000C | Settings | Schema already exists |
0x2000000D | Settings | Schema registry full |
| FPGA | ||
0x2C000001 | FPGA | Program not found |
0x2C000002 | FPGA | Program registry full |
0x2C000003 | FPGA | Invalid .vmprog package |
0x2C000004 | FPGA | Package hash mismatch |
0x2C000005 | FPGA | Package signature invalid |
0x2C000006 | FPGA | No matching bitstream variant |
0x2C000007 | FPGA | SPI transfer to FPGA failed |
0x2C000008 | FPGA | FPGA configuration timeout |
0x2C000009 | FPGA | Bitstream read failed |
0x2C00000A | FPGA | Unknown parameter ID |
0x2C00000B | FPGA | Parameter bridge write failed |
0x2C00000C | FPGA | Parameter bridge full |
0x2C00000D | FPGA | Invalid FPGA state for operation |
0x2C00000E | FPGA | Service not initialized |
0x2C00000F | FPGA | Filesystem error during program load |
0x2C000010 | FPGA | Configuration already in progress |
0x2C000011 | FPGA | Configuration not started |
0x2C000012 | FPGA | No DMA channel available |
0x2C000013 | FPGA | DMA transfer busy |
0x2C000014 | FPGA | DMA bridge init failed |
0x2C000015 | FPGA | Bitstream decompression failed |
0x2C000016 | FPGA | Video timing not supported by program |
0x2C000017 | FPGA | Crypto verification failed |
0x2C000018 | FPGA | Passthru program not found |
| UI | ||
0x30000001 | UI | Invalid button index |
0x30000002 | UI | Invalid LED index |
0x30000003 | UI | Invalid toggle index |
0x30000004 | UI | Scan loop not running |
0x30000005 | UI | Service already running |
0x30000006 | UI | Pin not configured |
0x30000014 | UI | Potentiometer ADC read error |
0x30000015 | UI | Potentiometer value out of range |
0x30000016 | UI | Potentiometer signal too noisy |
0x30000017 | UI | Invalid potentiometer channel |
| Video | ||
0x34000001 | Video | Sync service not initialized |
0x34000002 | Video | Sync service already initialized |
0x34000003 | Video | GPIO IRQ registration failed |
0x34000004 | Video | Invalid sync pin config |
0x34000009 | Video | Analog decoder not configured |
0x3400000A | Video | Analog encoder not configured |
0x3400000B | Video | HDMI receiver not configured |
0x3400000C | Video | HDMI transmitter not configured |
0x3400000D | Video | Unsupported video connector |
0x3400000E | Video | Unsupported video timing |
| Localization | ||
0x38000001 | Localization | Language not supported |
0x38000002 | Localization | String not found |
| Pseudorandom | ||
0x3C000001 | Pseudorandom | Stream pool exhausted |
0x3C000002 | Pseudorandom | Invalid stream ID |
0x3C000003 | Pseudorandom | Stream not allocated |
| Screen | ||
0x40000001 | Screen | Invalid screen index |
0x40000002 | Screen | LCD self-test failed |
0x40000003 | Screen | Service already running |
| MIDI | ||
0x44000001 | MIDI | Unknown fault |
0x44000002 | MIDI | Receive buffer overflow |
0x44000003 | MIDI | Protocol parse error |
0x44000004 | MIDI | Invalid MIDI message |
0x44000005 | MIDI | UART port not ready |
0x44000006 | MIDI | UART hardware error |
0x44000007 | MIDI | MIDI-CI message malformed |
0x44000008 | MIDI | MIDI-CI MUID conflict |
0x44000009 | MIDI | MIDI-CI profile list full |
0x4400000A | MIDI | MIDI-CI profile not found |
0x4400000B | MIDI | MIDI-CI unsupported message type |
| Motion | ||
0x4C000001 | Motion | Invalid BPM value |
| Modulation | ||
0x50000001 | Modulation | Invalid modulator |
0x50000002 | Modulation | Invalid source |
| Shell | ||
0x58000001 | Shell | Unknown command |
0x58000002 | Shell | Command parse error |
0x58000003 | Shell | Required service unavailable |
0x58000004 | Shell | Input buffer overflow |
0x58000005 | Shell | USB CDC not connected |
0x58000006 | Shell | File not found |
0x58000007 | Shell | I/O error |
0x58000008 | Shell | SD card not mounted |
0x58000009 | Shell | Path too long |
0x5800000A | Shell | Invalid path |
| Preset | ||
0x5C000001 | Preset | No FPGA program loaded |
0x5C000002 | Preset | Invalid preset index |
0x5C000003 | Preset | Preset slot empty |
0x5C000004 | Preset | Invalid preset name |
0x5C000005 | Preset | Save to flash failed |
0x5C000006 | Preset | All user preset slots full |
0x5C000007 | Preset | Save data malformed |
| USB | ||
0x60000001 | USB | Device not mounted |
0x60000002 | USB | Device buffer full |
0x60000003 | USB | Report generation error |
