Skip to main content
Test Images
Reference image library for video processing development and testing. All 79 images are lossless PNG — no JPEG, TIFF, or other formats. 79 images across 5 collections, totalling ~29 MB.
Collection Summary
CollectionImagesFormatResolution RangeSize
Kodak Lossless True Color24PNG768×512 / 512×76815 MB
USC-SIPI Color14PNG256×256 – 512×5123.7 MB
USC-SIPI Grayscale25PNG256×256 – 1024×10244.3 MB
Test Patterns10PNG1920×10804.0 MB
Grayscale from Kodak6PNG512×768 – 768×5121.4 MB
Total79~29 MB
Source: Kodak Lossless True Color Image Suite License: Released for unrestricted non-commercial use Format: PNG, lossless, 24-bit RGB
The Kodak suite is the most widely used reference set in image processing research. 24 high-quality photographs covering landscapes, portraits, architecture, and still life.
PreviewFileDimensionsSizeDescription
kodim01.png768×512719 KBStone building
kodim02.png768×512604 KBRed door
kodim03.png768×512491 KBHats
kodim04.png512×768623 KBPortrait of girl in red (portrait orientation)
kodim05.png768×512767 KBMotocross bikes
kodim06.png768×512605 KBSailboat at anchor
kodim07.png768×512553 KBShuttered windows
kodim08.png768×512770 KBMarket place
kodim09.png512×768569 KBSailboats under spinnakers (portrait)
kodim10.png512×768580 KBOff-shore sailboat race (portrait)
kodim11.png768×512606 KBSailboat at pier
kodim12.png768×512519 KBCouple on beach
kodim13.png768×512803 KBMountain stream
kodim14.png768×512676 KBWhite water rafters
kodim15.png768×512598 KBGirl with painted face
kodim16.png768×512522 KBTropical key
kodim17.png512×768588 KBMonument, Cologne (portrait)
kodim18.png512×768763 KBModel in black dress (portrait)
kodim19.png512×768656 KBLighthouse in Maine (portrait)
kodim20.png768×512481 KBP-51 Mustang
kodim21.png768×512622 KBPortland Head Light
kodim22.png768×512686 KBBarn and pond
kodim23.png768×512545 KBTwo macaws
kodim24.png768×512690 KBMountain chalet
USC-SIPI Color
Source: USC-SIPI Image Database — Miscellaneous Volume License: Available for research use Format: PNG, lossless, 24-bit RGB (converted from original TIFF)
Standard color test images from the USC Signal and Image Processing Institute.
airplane_f16_512.png512×512414 KBF-16 fighter jet (4.2.05)
couple_ntsc_256.png256×256106 KBCouple, NTSC colorspace (4.1.02)
female_256.png256×256103 KBFemale portrait (4.1.04)
female_belllabs_256.png256×25692 KBBell Labs female portrait (4.1.03)
female_ntsc_256.png256×256116 KBFemale, NTSC colorspace (4.1.01)
house_256.png256×256109 KBHouse exterior (4.1.05)
house_512.png512×512447 KBHouse exterior, hi-res (4.2.06)
jellybeans_256.png256×25675 KBJellybean candy (4.1.07)
jellybeans_alt_256.png256×25684 KBJellybean candy, alternate (4.1.08)
mandrill_512.png512×512612 KBMandrill baboon (4.2.03)
peppers_512.png512×512494 KBBell peppers (4.2.07)
sailboat_512.png512×512534 KBSailboat on lake (4.2.04)
splash_512.png512×512384 KBWoman in pool (4.2.01)
tree_256.png256×256130 KBTree (4.1.06)
USC-SIPI Grayscale
Source: USC-SIPI Image Database — Miscellaneous & Aerials Volumes License: Available for research use Format: PNG, lossless, 8-bit grayscale (converted from original TIFF)
Standard grayscale test images widely used in image processing literature.
aerial_256.png256×25648 KBAerial photograph
aerial_512.png512×512173 KBAerial photograph, hi-res
airplane_256.png256×25630 KBAirplane
airplane_512.png512×512105 KBAirplane, hi-res
airplane_u2_1024.png1024×1024595 KBU-2 reconnaissance aircraft
airport_1024.png1024×1024704 KBAirport aerial
apc_512.png512×512146 KBArmored personnel carrier
car_apcs_512.png512×512149 KBCar and APCs
car_apcs_alt_512.png512×512150 KBCar and APCs, alternate view
chemical_plant_256.png256×25644 KBChemical plant
clock_256.png256×25633 KBClock face
couple_ntsc_512.png512×512144 KBCouple, NTSC source
fishing_boat_512.png512×512163 KBFishing boat
male_1024.png1024×1024635 KBMale portrait
moon_256.png256×25641 KBMoon surface
pixel_ruler_512.png512×5121.5 KBPixel ruler / measurement chart
resolution_chart_256.png256×25611 KBResolution test chart
step_wedge_21level_512.png512×5121.6 KB21-level grayscale step wedge
stream_bridge_512.png512×512158 KBStream and bridge
tank_512.png512×512158 KBTank
tank_alt_512.png512×512168 KBTank, alternate view
tank_side_512.png512×512164 KBTank, side view
truck_512.png512×512152 KBTruck
truck_apcs_512.png512×512174 KBTruck and APCs
truck_apcs_alt_512.png512×512173 KBTruck and APCs, alternate view
Test Patterns
Source: Generated locally with ImageMagick License: Public domain (synthetic) Format: PNG, lossless, 1920×1080 (Full HD)
Synthetic test patterns for calibration, alignment, frequency response, and color accuracy testing.
PreviewFileSizeDescription
smpte_bars_100pct_1920x1080.png5.1 KBSMPTE color bars at 100% amplitude — full-range color reference
smpte_bars_75pct_1920x1080.png5.1 KBSMPTE color bars at 75% amplitude — broadcast-standard levels
grayscale_ramp_h_1920x1080.png7.3 KBHorizontal grayscale gradient (black→white) — gamma/linearity test
grayscale_ramp_v_1920x1080.png7.3 KBVertical grayscale gradient (black→white) — vertical linearity test
rainbow_1920x1080.png96 KBFull hue sweep (H: 0°–360°, S: 100%, V: 100%) — chroma test
zone_plate_1920x1080.png3.8 MBSiemens zone plate — spatial frequency response, aliasing detection
checkerboard_1920x1080.png16 KB8×8 pixel checkerboard — sharpness and spatial alignment
white_1920x1080.png1.3 KB100% white field — clipping, uniformity, and flat-field test
gray_50pct_1920x1080.png4.2 KB50% gray field — mid-level linearity and noise floor
black_1920x1080.png409 B0% black field — black level, pedestal, and noise floor
Source: Lossless grayscale conversions of selected Kodak suite images License: Same as Kodak suite (unrestricted non-commercial use) Format: PNG, lossless, 8-bit grayscale
Grayscale images for testing luminance processing, edge detection, and monochrome pipelines.
PreviewFileDimensionsSizeSource
kodim01_bw.png768×512263 KBGrayscale of kodim01.png — stone building, fine detail
kodim04_bw.png512×768216 KBGrayscale of kodim04.png — portrait of girl in red (tests luma mapping)
kodim08_bw.png768×512264 KBGrayscale of kodim08.png — market place, motion
kodim13_bw.png768×512293 KBGrayscale of kodim13.png — mountain stream, high detail
kodim15_bw.png768×512208 KBGrayscale of kodim15.png — girl with painted face
kodim23_bw.png768×512189 KBGrayscale of kodim23.png — two macaws, high frequency
Usage Notes
Resolution & Cropping
Images span a range of resolutions (256×256 to 1920×1080). For testing at a specific target resolution (e.g., 1920×1080 HD or 720×480 SD), use ImageMagick to crop or resize:
# Center-crop to 1920x1080
# Resize (fit within, maintains aspect)
# Resize (exact, may distort)
Format Conversion
# To raw RGB bytes (for FPGA testing)
convert input.png -depth 8 rgb:output.raw
Grayscale Conversion
# Color to grayscale (luminance-weighted)
